Strip screws? How to fix?
Hi i screwup my side console, by stripping one of the screws. ( i used a y00 instead of a y000). Rubber band and super glue didnt work. To remove glue i use a drill bit (1mm), now there is a counter sunk hole. Ideas?
Sounds like you already have drilled a hole there so I would just get the next biggest drill bit and drill it more. You might even need to use the next biggest bit after that. Once you drill the head off then you can usually take it apart more until you can get to the screw and use pliers to turn it out.
Hope this makes sense.
这个答案有帮助吗?
Try this
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 20
过去 30 天: 143
总计 32,078
