跳转到主内容
The Roomba 650 is a Fourth Generation robotic vacuum released by iRobot in August 2012. This device is hand-free and is programmed to clean our homes. With little manual operation needed, this robot have revolutionized house cleaning.
Roomba won't leave the dock
Hi, my Roomba 650 won't leave the dock anymore. It won't do it on schedule nor when I press the clean button. If I take it off the dock it will work perfectly and dock itself as well. I suspected a battery issue and changed the battery but this didn't help. I've also reset the Roomba a few times and moved the dock to different places.
I haven't seen anyone having this problem even after some serious searching. Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
8条评论
It must be scared of your cat ;-}
How old is the unit? You may need a fresh battery pack as it thinks the charge is not enough or the logic is damaged.
完成的
I already changed the battery.
完成的
I guess I just have to start the Roomba manually. There is hundred problems with hundred answers, but of cource I got a unique one. :)
完成的
I'm having the same issue. When I press the clean button, it leaves the dock for 5 mins or so then goes back to the dock. When I pick it off the dock and start it out in the room, it ran for about 15 mins.
完成的
This is not the same. When I press the Clean-button while my Roomba is on the dock nothing happens. Out of the dock it works perfectly and cleans at least an hour. Your problem definitely sounds battery related.
完成的
显示更多的3条评论
添加一条评论
4个答案
最有帮助的答案
I’m having the same problem with my 690. I can tell Alexa to turn it on and if it’s docked it will light up as if it were going to leave, but then it doesn’t. It will only work if I manually start it off the dock and then it operates normally. I will post here again if I figure out the problem.
这个答案有帮助吗?
得分 1
添加一条评论
You Hey Ville,
I would suspect there is a problem with your docking station, saying that you said if you take it off it will run fine (correct me if I'm wrong). I would attempt to contact the company if you are still in warranty to get a replacement.
Update (05/08/2018)
Try this then, [http://Factory Reset Roomba|https://youtu.be/YWumDMTvpsU]
这个答案有帮助吗?
得分 0
2条评论:
No warranty I’m afraid. The dock charges the Roomba fine and docking works too...
完成的
I have done the reset multiple times as I mention in my question.
完成的
添加一条评论
Hi did you solve your problem as my roomba 774 is doing the same exact thing?
这个答案有帮助吗?
得分 0
1条评论:
No, its still the same. I have scheduled the robot to start everyday at the same time and if I want it to clean I pull it off the dock on the morning. Not a real solution, but at least I can use it when I'm at work this way.
完成的
添加一条评论
My husband dropped my roomba and now it won’t come off the dock or clean and I don’t know what to do if I take it off and press clean it says error 1 take it to a new spot and push clean but it says the same thing every time
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ville Veijalainen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 28
总计 11,338
