跳转到主内容
加入维修社区 - 创建账户
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
Model 917 Differential Problem
Tractor, YTS4000, 24hp 6 speed manual-- has difficulty turning. To me it seems the differential is locked as the front wheels continue to want to plow forward while turning. (This is not a "steering" problem as the front wheels turn fine) What I see: This winter when using the snow blower as I attempted to turn right, the right rear wheel was spinning!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
You are 100% correct. It thinks it is a drag-racer with 'posi-track' !
完成的
添加一条评论
2个答案
已选择的解决方案
@tlien this mower uses a transaxle. See if you can find a tag or manufacturers number on it. If there is none check the attached image for an ID and let us know if there is a match.
This is not an answer but the only way to post an image. I shall delete it once I have clarification from the OP No reason to downvote it yet ;-)
这个答案有帮助吗?
得分 1
1条评论:
Need to replace the two Drive belts on a 42-in craftsman motor
完成的
添加一条评论
最有帮助的答案
If you're a 'shade-tree-mechanic', you can save a few bucks by removing the unit, and take it to the shop for repair. Or, fix it yourself. These machines were not known for their longevity, plus differentials are expen$ive, so I would make it a D.I.Y. project.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Terrence Lien 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 13
总计 432
