跳转到主内容
The current line of iPod touch comprises seven (7) different generations.
2619 个问题 查看全部
iPod dissable please conect to itunes.
i have a ipod touch 4g that says ipod dissable conect to itunes, i change the password and after i try to many times it lock by it self. how caN I fix this problem? i already put it into dfu mode and it didnt work
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
osvaldo, have you tried this from here
1. Connect your iPod Touch to iTunes
2. Press or Hold the power and home keys 10 seconds.
3. Screen goes black, now release the power button
4. Make sure you do not release the Home key until your iTunes says "We have detected an iPod Touch in recovery mode."
5. Restore the iPod
and if you are using a PC, there is one more way if you do not want to lose your data First plug in the ipod, go to My Computer. Click on the ipod drive, then go to tools > folder options. Then click view, click show hidden files. Go to ipod_control. Then go to device there should be a file named "_locked" ,delete that. Unplug the ipod and you should be ready to go hope this makes sense,
这个答案有帮助吗?
得分 1
添加一条评论
Hi, there. If you entered too many times' wrong lock screen passcode on your iPod, it will prompt that iPod is disabled. Don't be nervous though. It just means that you cannot use your iPod until the passcode is unlocked. As a matter of fact, you can use recovery mode to bypass the password.
Tenorshare ReiBoot helps you enter and exit iOS recovery mode with one click. It is free and safe, neither need to connecting to iTunes to restore, nor need to damage your device. Try it if needed.
这个答案有帮助吗?
得分 0
2条评论:
Hi osvaldo,
my ipad model is A1430 and its with the same common problem with foggoten id & password problem. it gives a message saying " this ipad was lost & erased" . how can I come out this problem.... please help my mail address is
roshan@multilines.net
Will be a great help if you could help me with the process
完成的
Dear osvaldo,
Also note that I am from Sri Lanka and weather connecting from here will work
完成的
添加一条评论
添加你的答案
osvaldo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 6
总计 1,191
