跳转到主内容
Wi-Fi only variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
20 个问题 查看全部
iPad 5 won't power up after digitizer replacement
I replaced the digitizer on my iPad 5 as well as the home button. Prior to the screen replacement, the iPad was perfectly operational, it just had the broken screen.
Everything with the replacement went as expected although it was very tedious. I did not manage to get the touch id home button out in one piece so i used the one provided with my digitizer which was already in place. The only thing that I didn't realize on the front end was the battery disconnection because it was not in the fixit video I had watched a million times before I started. After everything was back in place, the iPad will not boot up at all.
The screen remains black not even a faint apple logo. I've tried all of the restart, restore, DFU options I've been able to find online. I've tried leaving it charging with an apple certified charger that works with other devices directly in the wall overnight. I've tried plugging it into my computer and it is not recognized at all. I've taken it apart and reassembled and double checked the seating of the digitizer, home button and LCD multiple times (like 9 at this point). I've also tried disconnecting the battery with a pick and doing the disassemble and reassemble again. Finally I tried tapping/hitting the back gently...
So is this a lost cause? have I shorted the logic board out somehow in the process? I used the plastic tools provided. Is there anything else I could test or try? Is it possible that it wouldn't boot up if I got a faulty digitizer and home button?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Well,you've done a great job researching possible solutions and assuming you applied them properly, everything points towards a logic board issue. You could have damaged the charging circuit, which would impede the startup of the device or you could have nicked or dislodged some components. About the only thing you haven't tried is to inspect the board under magnification to see if there's anything obvious.
At this point, your best bet is to have it looked at by an experienced micro-solderer.
这个答案有帮助吗?
得分 3
2条评论:
Boo, I was hoping for some magical answer that I had missed that would fix it. Thank you for your response! Given that they're $240 refurbished I'm guessing I won't save anything to continue pursuing this :(
完成的
You can probably have it repaired for much less than that...just call a few shops that do micro-soldering repairs.
完成的
添加一条评论
添加你的答案
glenna 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 467
