跳转到主内容
加入维修社区 - 创建账户
JBL E45BT 发布于 2017 年,是一款配备蓝牙 4.0 和 40 毫米驱动单元的无线贴耳式耳机,电池续航时间长达 16 小时。
How do I open it up?
So i dropped my headset and i didnt see anything wrong with it untill i tried to turn it off.
it seems to power button got stuck and cant fully move to the top, so i want to open it to see how but i cant seem to find anything on youtube and i cant seem to figure it out myself.
if anybody can help me that would be nice.
thank you and have a nice day
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 10
4条评论
Happened to me exactly the same.. what did you do in the end?
由完成的
* What size is that triangle bit?? I just ordered the pro-tech bits and none fit the headphone.
由完成的
Is their anyway I can turn it on without that even if it’s stuck
由完成的
Use a very small torx but for the triangles. Pop the knurled right off the outside of the headphone to reveal the screws
由完成的
添加一条评论
6个答案
已选择的解决方案
I have a more complete writeup here How can I replace the headband wire?
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
For anyone having the same problem:
At first, remove the two triangle screws from the outside
Then just lift up the plastic-ring (it’s glued) - under it there are 4 screws, if you remove them, the casing will open up
这个答案有帮助吗?
得分 16
8条评论:
how do u even lift up the plastic-ring? it seem impossible
由完成的
its kinda difficult, just use the "Jimmy" Tool or some thin plectrums
由完成的
Before I tear the earpiece apart… is it worth while? My button is stuck but still operational. Will still turn on / off. Thanks :)
由完成的
What size is the triangle bit?
由完成的
Warren Duan: I used a flat head screwdriver that fit tightly between two points of the triangle screw and they unscrewed easily.
由完成的
显示更多的3条评论
添加一条评论
Hi there!, so this happend with me too and when I tried to click the power button of my JBL headphone it wasn’t doing anything. So to fix this there is no need to buy a new pair or get it fixed. All you need is a safety pin, unless you are careful and you don’t get any scratches all you have to do is try to pop it up but the side which has been buried
JUST LIKE THIS :):
这个答案有帮助吗?
得分 5
4条评论:
Hi there Kashvi,
I think it doesn't the same model, in E45BT the power button is not pressed, it's slide button.
由完成的
Thank you so much kashvi…it worked!!
由完成的
Yes its worked!!👍👍
由完成的
thank you so much youre my savior i was sobbing bcs i love these sm and live for music and podcasts and you saved me tysm omg
由完成的
添加一条评论
If these are anything like the other headphones I’ve disassembled there should be 3-6 screws hidden under the earpad foam. They will likely require a proprietary JBL bit. Here is a link to some triangle bits, one of which should be the correct size for your headphones. Hope this helps!
这个答案有帮助吗?
得分 1
添加一条评论
Has anybody finally found out why the slide button gets stuck before it reaches the end position? And maybe if there could be a fix without completely opening the affected ear shell?
Regards,
Wolfgang
这个答案有帮助吗?
得分 1
添加一条评论
I would say that some of the hardware in the head phones might have gotten messed up but that is probably not likely.
Usually the headphone will work after being dropped because JBLs are pretty tuff. Depending on the hight dropped, if they are somewhat new, I would ask for a refund because they are meant to be pretty tuff.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Guy 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 32
过去 30 天: 114
总计 32,847
