跳转到主内容
The W123 chassis covers 240D's, 300D's, 300TD's, 280E's, and several other models of Mercedes coupes, sedans and wagons from model years 1977 to 1985.
116 个问题 查看全部
Left turn signal will not blink when I press the break paddle.
Hi , my left blinker will not blink if the break paddle is pressed, it will sometime hesitate to blink and will blink once or twice. The right side seems fine, flasher relay replaced, the emergency switch is new. Again the right side is not affected at all. The left blinker will resume normal operation , when break paddle is not pressed. However what I noticed is a little green light is on where the arrow of the left blinker will blink on the instrument cluster if the break paddle is pressed , but the blinker switch not engaged to blink . Please help, I have no idea what is causing this..
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@darkr123 this sounds like your brake light is creating a short circuit and prevents your blinker to coming on. First thing to check is the bulb. Make sure that you have the correct bulb in it. You did not give us a year or prope model so we cannot tell you which bulb you need. The other thing you want to check is the wiring to the light as well as the bulb socket itself. Make sure that there is no corrosion as well as shaved wires etc.
这个答案有帮助吗?
得分 2
1条评论:
Hi, it’s W123 1983 Turbo Diesel.
完成的
添加一条评论
添加你的答案
Roee 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 79
