跳转到主内容
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
display LCD damage - flickering
Hi everyone,
I have a client who has a MacBook 13" with an LCD display that overtime (she says she didn't drop it) started flickering.
I wonder if I were to replace the entire top part (easier for me) if that will address the issue or if there is something more than just the LCD display. Also if someone were to fix the current one is it just that the backlight went out?
An image and video are attached.
Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
I would hook it up to an external monitor first to help isolate the problem.
Move the screen up and down and see if there is any change.
Run your finger along the bottom edge of the display where the board is and see if you get any changes.
这个答案有帮助吗?
得分 4
5条评论:
Hi @mayer,
Thanks for your reply, I connected it to an external display and it showed up fine, no issues. I just ran my finger along the bottom edge, the black hinge and also where it says MacBook and it doesn't seem to help.
Do you think the display connector came loose somehow but I don't think this is the case as the rest of the display is fine.
I'm assuming and the easiest way forward might be to replace the display with a new one off eBay. Thoughts?
Thanks.
完成的
@spearson48 My guess at this point, would be a damaged board on the back of the LCD. You can probably find just the LCD board on eBay.
完成的
I would add it's easier just to replace the complete display assembly while more expensive its a lot less work and less risk of damaging things trying to get the LCD panel off to get to the driver board or, just replace the complete LCD panel assembly.
完成的
@danj, that was what I was thinking as well, thank for the additional information.
完成的
Time vs money is always a factor. Sometimes I have the time and sometimes not.
完成的
添加一条评论
添加你的答案
spearson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 27
总计 544
