跳转到主内容
加入维修社区 - 创建账户
Motorola Moto Z Play(型号为 XT1635-02、XT1635-01 和 XT1635-02)是一款于 2016 年 9 月发布的安卓智能手机。Moto Z Play 的外观特征非常明显:机身正面顶部印有“moto”字样,底部配有一个方形主屏幕按钮。
Touch not working after screen replacement
I replaced the digitizer and OLED screen on my Moto Z Play and now touch isn't working on the screen. I made sure everything is seated properly, but it's just not working at all. The only thing I can think of is that somehow the zif connector for the pair isn't seating all the way in as the line on the cable does not sit exactly at the opening where the cable mates, but about a millimeter out from it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 7
添加一条评论
2个答案
I think you can check the contactors on the LCD screen flex cable, If you use too much force when you install, It might bend. Here has Moto Z Play LCD screen replacement video, I hope it will help you.
这个答案有帮助吗?
得分 0
4条评论:
I will try again tonight, but checking again, the line on the flex cable matches the guide line on the PCB, so I don't think that's the case.
Looking at the replacement screen (which was purchased from elsewhere), the chip on the flex cable that leads to the digitizer portion of the assembly is a spinortech chip, whereas the original had a synaptics chip, it must be a knockoff, but every listing I could find on ebay has a picture of the same chip, so I'm not sure.
完成的
I want to add that I ordered the replacement screen from ifixit now, it's twice as much as the one I had originally bought, but should just work, and actually cheaper than alot of the other OEM looking replacements available elsewhere
完成的
How did it go man?
完成的
Feel free to contact iFixit's customer support if you have any questions about the screen after install. However, this should fix the issue.
完成的
添加一条评论
According to Motorola this is a known issue and the data needs to be backed up on any Motorola phone before doing any repair. To fix the issue the phone needs to be factory reset. Before performing the factory reset make sure you do everything else as to not lose the customers data.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sean 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 3,967
