跳转到主内容
加入维修社区 - 创建账户
这款笔记本电脑于 2015 年发布,型号为 ba0709dx。维修该设备需要螺丝刀和撬具。
Caps lock flashing continuously
My HP 15 is not displaying after replacing an LCD and flashing caps lock continuously
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Yes its flashing continuously no pattern
由完成的
添加一条评论
1个答案
已选择的解决方案
Hi @vinnie263 ,
Are you sure that it blinks continuously and that there is not a pattern to the 'blinks' e.g. 2 slow blinks, 3 quick blinks, 2 slow blinks etc
Here is a link to the HP LED fault code diagnostic information which may be of some help.
这个答案有帮助吗?
得分 3
2条评论:
Its flashing continuously No pattern
由完成的
Hi @vinnie263 ,
You may have to go back and check your work.
You could try disconnecting the video cable from the motherboard (also the backlight power cable for the screen if it is a separate cable) and see if this gets rid of the flashing light
Do all the work with the power disconnected (this includes the battery)
You did disconnect the battery from the laptop when you replaced the screen didn't you?)
由完成的
添加一条评论
添加你的答案
Vincent Mutombo 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 29
总计 4,765
