跳转到主内容
Guides and repair information for Ninja blenders.
128 个问题 查看全部
I actually have a Nutri Ninja Auto-iQ BL481-70 and need the base gear
The inside rubber part of the blender that's connected to the base not the blade (not sure what it's called) came loose and won't screw back on. It appears the treading is worn out. So far, I've only been able to find the rubber gear that you connect to the blade only. Any ideas?
Update (04/24/2018)
Sorry about the photos. I've provided some more that should be clearer.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Marion Bee your image is a bit hard to see. If it is the external thread on the rotor it will be difficult to repair that but it's possible by rethreading it. Your image looks like part of the gear is still on the shaft. Take another picture of the gear (picture #2) but this one from the underside. It is possible that ll you have to do is to replace that gear. You must however remove the leftover part form the thread end of the rotor first. Again, it will help if you can post well lit clear images of those parts with your question.
这个答案有帮助吗?
得分 2
1条评论:
Sorry about the photos. I've provided some more that should be clearer. I was thinking of replacing the gear but haven't been able to find it online. I've only been able to find the blade gear. Do you have any idea where I could find it?
完成的
添加一条评论
添加你的答案
Marion Bee 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 428
