跳转到主内容
加入维修社区 - 创建账户
HX9360 can't turn on
I measure the battery about 3.8V.(F1 /R6 point).So I think the battery is fine.
But I push the button can't turn on it.But put into the cup can charge the battery.
So how do I to check the board or more action?
thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I have probably a similar issue. Who can find and change a battery here?
完成的
添加一条评论
2个答案
最有帮助的答案
swat1230 your voltage maybe fine but it is not a good indication of your battery being okay. It is possible that your battery simply does not hold enough charge to supply the demand. I'd start with a new battery first, then re-evaluate. Check your switch circuitry etc. with your multimeter.
这个答案有帮助吗?
得分 3
添加一条评论
I'm having the same problem. Have you fixed it?
Thanks!
这个答案有帮助吗?
得分 1
2条评论:
I have also checked the switch circuitry, which is fine. Additionally I have also connected an external power supply with 3.8V. Unfortunately it didn't helped.
完成的
I have exactly the same issues, battery power is still good. Have so. fixed the problem yet?
完成的
添加一条评论
添加你的答案
swat1230 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 14
总计 2,407
