跳转到主内容
2003年10月,iBook G4 取代 iBook G3 成为苹果的消费级笔记本电脑产品。iBook G4 提供12英寸和14英寸机型,最后更新于2005年。
Why won't it pick up a charge?
My iBook g4 won't take a charge. I have plugged it in to many different outlets and it wont pick it up. What happens is I will have to unplug my charger and eventually my computer will die, and then when I try to plug it in again it won't work. I bought a new charger for it and it still wouldn't work. I dont think anything is wrong with the computer because the light on the outside will continue to pulse until it completely dies. I just don't know what to do.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Will your iBook start up with the battery removed and just the AC adapter plugged in?
完成的
添加一条评论
1个答案
最有帮助的答案
Megan,
Have you tried a new battery? The next time you have it on, try to check your battery's health. iStat Pro is a great dashboard widget that gives you a lot of information on your computer... including battery health.
http://www.islayer.com/apps/istatpro/
iFixit appears to only carry the 14-inch battery.
[关联产品丢失或禁用: IF184-002]
It sounds like you could have an issue with your DC-in board... but that's step number two. It could be your battery connector or even your logic board.
Check your battery health with iStat Pro, then try the battery, then try the DC-in board and then come back here if it's still not working.
[关联产品丢失或禁用: IF184-003]
[关联产品丢失或禁用: IF183-030]
Choose one depending on which iBook G4 you have: 14 or 12 inch.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Megan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 3,185
