跳转到主内容
福特汽车的修理和支持指南。
1396 个问题 查看全部
1996 Ford Taurus will not start
I have a 1996 Ford Taurus. I went out and l had no problems starting the car. I forgot my phone so l came back home. Turned the car off. When l went back to my car it would not start. I had no problems before. 2 years ago l got a new starter put in from Ford. I bought a new battery and cleaned battery terminals. When l turn the key there is no noise at all. The dash lights do turn on. Please help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Pat Young okay so your are not getting any power. check the battery cables to make sure they are connected. Check to see if your have a good ground from the battery. Check your battery to make sure it is not dead. Check the battery cable connectors to ensure they are nor corroded off. Temporarily connect a know good battery to your Taurus with some booster cables. Check if that will provide the power you need. check to see if you have power on the "Mega Fuse" and if it has continuity. Let us know what you find.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Pat Young 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 412
