跳转到主内容
加入维修社区 - 创建账户
发布于 2013 年 型号:ONETOUCH 7024W FCC ID:RAD386
Problems Sending and Receiving Messages
When someone attempts to message me, their text comes thru multiple times (as many as 5 times). My response also comes thru multiple times. This is annoying. Please help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I can't send a text at all
由完成的
添加一条评论
1个答案
已选择的解决方案
Hi @justlittleoldme ,
Try starting the phone in safe mode and see if the problem still occurs.
If it still occurs in safe mode then try a master reset (also known as a factory restore or hard reset) and see if this resolves the problem
If it doesn't occur in safe mode then a downloaded app is the cause of the problem. The trick is to find out which one.
Try to recall when this first started happening and then check if there has been any new apps installed on the phone or if any existing downloaded apps have been updated around about the same time that it started.
If so try uninstalling it (or them if more than one) one at a time and testing the SMS function between each uninstall.
Once the problem has cleared, the last app that you uninstalled was the culprit.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Elaine 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 4,586
