跳转到主内容
The Comfort Zone CZ6C is a light gray portable desk fan. It has a six inch blade, two speeds, and a hinge mechanism on its neck.
4 个问题 查看全部
Can I add a drop of oil to small fan motor? Where?
Fan was working fine. Turned it off. Next time I switched it on, it was trying to get up the power to spin the blade, but couldn't quite do it. The blade would move a fraction of an inch, then no more. I cleaned it, but thought a drop of oil might help lubricate it again. Doable? Where to apply the oil?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Took it apart, cleaned dust and debris away. Put single drop of sewing machine oil in back of unit, moved motor shaft around to spread oil. Works better than when it was new!
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
I can find nothing about oiling this motor. Here's the trouble shooting guide on it: Comfort Zone CZ6C Troubleshooting
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Marge McCoy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 10
总计 978
