Ps4pro Sounds like a jet, solution please?
So my Ps4pro sounds like a jet, I borrowed my friend's to compare and make sure, my friend's is whisper quiet in comparison. Even in 1080p it still sounds embarrassingly loud. I saw your post in YouTube about loud standard ps4 and how changing the fan solves the problem.
My question is, does the same fix work on pro too!? Are you positive that there won't be any "anomalies" after I have the fan replaced?
I'd appreciate the !&&* outta an good answer.
Update (05/12/2018)
So fan replacement didn't work either. I live in a place without official sony repair centers, can anybody help?
2条评论
Hi Bro Try To Reinstall System Software , You Can Download It From Sony Support and Install , But Recovery Firmware Will Be Format Your Hard Disk and Erase All Data and PSN Accounts , I Offer To You After Install Is Complete Go To The Safe Mode Menu and Choose Rebuild Database Hope You Problem Fix With This Trick !
由 mortezatroy 完成的
The definitive solution here:
Dont bother go into safe mode and do what most people say about noise reduction. The problem with the PRO models is the power supply limits the air flow.
1st a general thing is:
Make a good cleaning and apply MX-4 thermal paste on the APU. The perfect amount here https://www.youtube.com/watch?v=xSgAoI_5... on 6:30 minuts
After that the IMPORTANTE PART is, on the power supply remove the metal shield and the top cover on the PSU and put back the botton plastic and the power supply board on the console with the cuicuit board striped. Be aware the power rails are dangerous (use gloves). Put the screws back in the right place and put back toghether the console cover and you are go to go.
I have my 7116b Pro model near the Xbox one X and i cannot here none of them working :-)
To get the idea i saw the solution here
https://www.youtube.com/watch?v=UT-QqkRy...
由 Carlos Saraiva 完成的
