跳转到主内容
加入维修社区 - 创建账户
适用于 2017 年 1 月 16 日发布的 Nvidia 独立游戏控制器的维修指南和支持。
Nvidia Shield Controller (2015) touch buttons replacement?
So a while ago my 2015 1st gen Nvidia shield front touch buttons stopped working, and I thought it was a bad 12-pin cable. It turns out it's the touch buttons (nvidia button, home button, back button, and play button) that stopped working. I have searched far and wide for a replacement but haven't found anything. Can anyone direct me to where I can find one?
Thanks for responses in advance :)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Mine also stops working but it’s a firmware issue. Recently I found out, when I cut out the power by disconnecting the battery from a 2015 controller and plugged back in everything works like a charm until I reboot or shut down the console. So I made a workaround. I drill a hole on a controller and connect a switch to the battery. It was annoying the old way now I just hit the diy switch off and on and everything works fine
Regards
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Matrucious 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 34
总计 2,075
