跳转到主内容
加入维修社区 - 创建账户
2012 年 11 月发布的第二代手机。提供隐形黑或极地白两种颜色 / 32 GB 或 64 GB 存储空间 / 使用 Micro SIM 卡 / 无 SD 卡槽。型号 #PM63100
battery discharge very fast
When i charge my phone and complete charging then when i started to use my phone
it is immediately shut down
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Hi mfshahri, could you solve your problem?
完成的
添加一条评论
1个答案
最有帮助的答案
@maxnet ….either one of two thing is happening. your phone goes into a charging state but is not actually supplying voltage to your battery or your battery has dead cells and is not actually taking a charge. you can test which one it is by verifying the voltage is travelling from your charging port to your battery terminal. if the voltage is there, change your battery. if not, start troubleshooting your charging port circuit. here is some basic troubleshooting guides for your phone:
HTC One X+ Troubleshooting
you can also test your battery to see if its short or taking a charge by reading its internal voltage at different intervals while charging.
技巧 - 测试电池
hope this helps. post back here for any further assistance
这个答案有帮助吗?
得分 1
2条评论:
Thank you very much. For me it was the battery. As I swapped it, it works again.
完成的
good to hear. good job.
完成的
添加一条评论
添加你的答案
mfshahri 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 7
总计 292
