跳转到主内容
加入维修社区 - 创建账户
Asus X555L 是一款于 2015 年 5 月发布的经济型笔记本电脑。这些指南中介绍的机型为 X555LA-SI305041,这是一款搭载 Intel Core i3 处理器的笔记本电脑,旨在为消费者提供经济实惠的选择。 类似机型:X555LB、X555LD、X555LF、X555LI、X555LJ、X555LN 和 X555LP
Factory Reset Gone Wrong
My laptop was being very slow, to the point where i simply couldn't open two applications at once. I decided to factory Reset the whole thing, i've done this previously on other laptops so i didn't see the problem. After the reset i closed down the laptop and left it for a few weeks. I tried to go on the laptop in question yesterday and it is not accepting the password (I haven't changed the password and i am certain of what it is). The password hint has also changed, it is missing letters and words. I have tried to create a password reset disk using another computer and this has still not worked, it throws up errors when i try to reset my password. I am totally lost on what to do. The F8 and F9 button seem not to work or respond and I feel like i have tried everything obvious. There is no way of getting into the laptop but it looks totally fine.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi ,
Since you've already done a reset once, try doing it again.
You've got nothing to lose except a bit more time.
这个答案有帮助吗?
得分 2
5条评论:
I can't get onto the system to do another reset, It was my first thought but theres no way how. Any ideas?
由完成的
Try using a Win 10 recovery USB and boot from it to reset the laptop.
The USB recovery drive can be created from any known working Win 10 PC. Go to Control panel > recovery > Create USB recovery drive
You'll need 8GB flashdrive and 40-60 minutes of time.
Don't forget to enable USB legacy or CSM in BIOS settings of laptop and alter boot option to USB drive as 1st option.
由完成的
How do I do the last part?
"Don't forget to enable USB legacy or CSM in BIOS settings of laptop and alter boot option to USB drive as 1st option."
由完成的
The F9 key won't work at all.
由完成的
Hi,
For your laptop press F2 during POST. i.e after laptop starts and before Windows boots to enter BIOS setup.
p.66 of the User Guide
You have to get the timing right. If too early the PC will beep at you and stop. Let go the F2 wait 0.5 sec and press F2 again. Another way is to continually keep tapping F2 until you see BIOS screen.
If pressing F2 too late and Windows starts to boot up, press and hold Power button until laptop shuts down and then start again.
You can also change boot order in BIOS
由完成的
添加一条评论
Dose the machine boot into windows, in other words is it a windows password ? or is it like a Bios password ?
If its running windows 10 it may have switched to your microsoft account. try the password of that.
这个答案有帮助吗?
得分 0
2条评论:
I've tried the windows password and it won't accept this.
由完成的
can you take a photo of the password screen your seeing and upload it here ?
由完成的
添加一条评论
添加你的答案
sally wall 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 12
总计 3,800
