跳转到主内容
4.3" widescreen LCD display with a 333 MHz Processor. Model Number PSP98510. Repair for this device requires common screwdrivers and prying tools.
Wifi doesn't seem to be working. Is this fixable?
Every time I try to connect to wifi it tells me the signal is too weak. I've tried plugging it in to the PS3/PS4 and the router and no luck. Any ideas? Is there a way to replace the wireless card/broadband adapter?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
Hi!
While there is no user replaceable WiFi-Card, you could try reseating the antenna connector. Follow this guide until step 11 and unplug the cable that's marked with purple in the guide. If that does not work either get closer to the router or replace the main board. Note that even if you plug the PSP into a PS3/ PS4/ router via USB the internet connection won't be shared.
这个答案有帮助吗?
得分 2
4条评论:
Note that the PSP 2000 is an 802.11b only card. You will have to double check that the Wi-Fi on your router is set to allow ancient 802.11b.
完成的
@avanteguarde Yeah, right, I forgot about that. Most routers do support that old standard tough
完成的
@alexniculescu I agree it is supported, but it is disabled. The reason being is WPA2, especially WPA2-AES does not work with 802.11b.
完成的
I was also wondering about the 802.11b. That would probably make a difference as well. Thanks for the help guys.
完成的
添加一条评论
It will always say signal too weak. There is nothing wrong with the WiFi card, but the communication protocol is outdated and no longer supported, hence the said error.
Just buy an old router that is still compatible and bridge to your network.
这个答案有帮助吗?
得分 1
添加一条评论
https://youtu.be/a4qjcvZ6xFE
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jbrady2 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 31
总计 2,278
