跳转到主内容
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
586 个问题 查看全部
Temperatur Improvement by replacing the Thermal Paste Some Values?
You Mentioned that it could be grate to replace the Termal Paste on these Models and use just the needed amount do you have run some tests how big the improvement in better CPU or GPU Temperatures really is on this model ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
take a look at these.. arctic silver 5 is the generally used paste for these things, the manufacturers claims 3-12 degrees lowering..
http://www.arcticsilver.com/#
这个答案有帮助吗?
得分 3
3条评论:
+ Nice way to answer. I normally use Arctic Silver 5, but everyone has their preference.
完成的
I used ceramique once but was unimpressed.. Swapped to no5 after a recommendation on here, I'd have to say it was easier to use and I've no complaints with the result on a few xbox 360 RROD. It's not a mac, but I'm sure Mayer uses it, in fact it may have been his recommendation!
完成的
+ that's 3-12 degrees lower than standard pastes. Yes I use the Arctic Silver. I didn't like the ceramique either.
完成的
添加一条评论
添加你的答案
Arne Glodde 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 5
总计 2,319
