跳转到主内容
Why is it beeeping
The beep code is 1-1-1-1-1-1 th en turns off I've tried removing all the parts and I had a cpu that was the same one I switched th e cpus and still beeps. I know it's not the ram cause I just got the ram 2 days ago. I haven't taken out the cemos yet I'll try that but if anyone knows how to fix I need the awnser.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
@mcofficalplays what make and model is your computer? What motherboard is it? Did it have this issue before you replace the memory? Have you tried the old memory
完成的
@mcofficalplays
list out the make and model as mentioned from oldturkey03
check on your graphic card and power supply also.
完成的
My computer is the Brodcast pix slate g 1000 i tryed removing the graphics card and I got this without ram but,with the ram type
完成的
@mcofficalplays try opening up the casing, take pictures of inside mainboard, perhaps install a working graphic card and see if it boots up
完成的
添加一条评论
2个答案
已选择的解决方案
The broadcast Pix slate G 1000 is not a typical computer. This is a highly customized machine with proprietary hardware for broadcast television video. I suggest posting on their forum for an answer.
这个答案有帮助吗?
得分 1
1条评论:
i will post there
完成的
添加一条评论
最有帮助的答案
If you just Google for your brand of motherboard suffixed by "beep codes" you may well find the answer.
这个答案有帮助吗?
得分 1
1条评论:
I can't it's a special motherboard made by the computer company that is the same one that made the computer.( The pc is a switcher)
完成的
添加一条评论
添加你的答案
McOfficialPlayYT 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 179
