跳转到主内容
加入维修社区 - 创建账户
Verizon Ellipsis 8 是一款平板电脑,配备高清显示屏、5000 mAh 电池以及 4G LTE 功能。
keeps rebooting ,optimizing app 135
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi,
It may be that a downloaded app is causing the problem.
Try starting the tablet in safe mode to check that it starts up OK without rebooting.
If it does then a downloaded app is the problem. The trick is to find out which one.
If you have just recently installed or updated some downloaded apps and then the problem started try uninstalling them first, one by one. Check between each uninstall if the problem has gone by trying to start the tablet in the normal way and see if the problem has gone. If it has then the last app uninstalled was the problem
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
gus pappas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 11
总计 1,002
