跳转到主内容
加入维修社区 - 创建账户
iPad Mini 2 LTE 版本指南。该设备于 2013 年 10 月 22 日发布,并于 11 月 12 日上市。iPad mini 2(最初称为配备 Retina 显示屏的 iPad mini)拥有与 iPad Air 相同的像素密度,但采用了更小巧的 7.9 英寸外形。
iPad mini 2 have charging problem
I have a iPad mini 2 here not charging.
It turns on everything but it does not charge.
Changed the battery, charging port, and charging ic.
All of the parts work cause I tested each part on another working device.
When I plug in the charger and turn on the device, it shows it's charging but it's fake charging. When I unplug it and plug it back in, it does not charge again.
I have noticed how the voltage drops when athe battery is connected to the device. When a cable is connected to the port, L5700 shows 5v.
With battery drops to 4v and when the device is turned on, its 3v, despite the charger plugged in.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
PPVBUS_USB (L5700) should not be dropping down to 3V when charging (or even 4V for that matter). To things could be going on here:
  1. The power source (charging brick or USB port) can't supply the necessary current and is being current limited , hence dropping the voltage.
  2. The power source is fine but the device is drawing excessive current due to a short or partial short somewhere.
If you have access to a USB Ammeter, you could use that to determine if the device is really drawing current when it says it's charging.
这个答案有帮助吗?
得分 2
1条评论:
The tablet automatically turns itself on when the screen and the battery is connected to the motherboard. Could this be one of the problem?
完成的
添加一条评论
添加你的答案
Sarbear 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 21
总计 956
