跳转到主内容
加入维修社区 - 创建账户
苹果于2015年10月14日发布的第二代桌面触控板。型号A1535。
Does Magic Trackpad 2's battery connector same with iPhone 5?
The battery connector seems to be same with iPhone 5.
Can I replace Magic Trackpad 2's battery by iPhone 5's battery for temporary?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
3条评论
Thank you all for detailed answer.
Since I can't find trackpad 2 in Mac and there is no response when I connect my trackpad 2 to Mac by lighting cable, I suppose if it is possible replaceing the battery to make sure what problem it is.
Maybe I have to buy the right battery first.
完成的
Sang that sounds like a very good first stop. That way you know for sure if it is a battery issue or not. Best of luck to you.
完成的
I replaced the right battery, but it didn't work at all. Certainly I checked the voltage of the new battery upto 4.1V, while the old one is 0V.
完成的
添加一条评论
3个答案
已选择的解决方案
Sang no you cannot. Different battery (we all know how finicky Apple devices are when it comes to batteries) and a different connector etc. Buy the right battery so you do not have to connect anything temporarily and avoid making costly mods and/errors.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Although it MAY be possible, for your own safety and devices I highly reccomend NOT doing this.
这个答案有帮助吗?
得分 1
添加一条评论
-> Magic Trackpad 2 Teardown
It seems that you can do it , but the battery will not have the same capacity (battery drop quickly).
There is very similar but not the same voltage. (drain battery also more quickly)
Also check it might require to change the connectors to install it,
might need soldering skills for that .... I don't recommend to do it for long last solution...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sang 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 17
总计 1,105
