跳转到主内容
JBL Flip 4 portable speaker. IPX7 waterproof bluetooth dual driver speaker that won the CES Innovation Award 2017.
77 个问题 查看全部
Not charging or turning on
My JBL speaker has been working fine and now nothing lights up even when it’s plugged in. I’ve used 3 diffrent cables to try and charge it with they don’t make a difference. Nothing has worked and it makes me sad. I’ve tried resetting it and again nothing happened, so I don’t know what to do.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
4条评论
i fixed it,
you have to put
pressure on the flat cable that is connected with the "power button/LED/ JBL Connect Chip". Then you have to put a cable back in the usb chip
after that it should work again
完成的
And how do you do that?
完成的
all of you are wrong!!!,
Did you check the 5v on the usb type v8 line?
Did you check the 5v on the usb board?
Did you check the 5v get to IC charging?
Did you check the 5v get to Batery?
Did you check the 3.3v & 2.7v & 1.2v to the PMIC?
完成的
how do i check all these? is there a kind of tutorial?
完成的
添加一条评论
1个答案
最有帮助的答案
If your JBL Flip 4 speaker refuses to turn on, see the JBL Flip 4 Won’t Turn On problem page for possible causes and solutions.
If your JBL Flip 4 speaker will not charge or won’t hold a charge, see the JBL Flip 4 Will Not Charge Or Won’t Hold a Charge problem page for possible causes and solutions.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Abigail J Rhea 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 33
总计 2,885
