Does your JBL Flip 4 no longer hold a charge for as long as it used to? Does it not charge at all? JBL Flip 4 speakers are susceptible to a range of problems that could cause them to stop charging or lose charge quickly. Check the following possible causes to identify and solve the problem.
Cause 1: Faulty Battery
If your JBL Flip 4’s battery is not charging or unexpectedly turns off, it may have a faulty battery. Before replacing the speaker’s battery, check to make sure that the speaker has not been left in abnormal temperatures, such as near a stove or fireplace. Abnormal temperatures can cause the device to lose battery power more quickly than normal. If the battery issues continue, use the JBL Flip 4 Battery Replacement Guide to replace the speaker’s faulty battery.
Cause 2: Faulty Charging Port
If your JBL Flip 4 still refuses to charge after replacing the battery, it may have a faulty charging port. To replace the speaker’s charging port, use the JBL Flip 4 USB Port Replacement Guide.
Questions other people have asked about this
- Flip 4's battery runs out quickly and other problems.
- My JBL Flip 4 doesn't turn on and charge.
- JBL Flip 4 is not charging
- Not charging or turning on
- JBL wont't turn on and takes no charge after failed to update firmware
0条评论
