跳转到主内容
加入维修社区 - 创建账户
Asus ROG Strix GL702VM-BHI7N09 是 Asus 于 2017 年 1 月发布的一款游戏电脑。
Replace broken internal speakers?
I bought new parts for the internal speakers, but I'm not sure how to install them. I have updated the audio drivers several times previously but to no avail. My guess is an acquaintance of mine accidentally blown the speakers resulting the problem.
Update (04/01/2018)
The audio worked fine when I was using my earphones.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi,
Is the audio OK when using headphones?
If not then perhaps the speakers are not the problem and you may have a problem with the audio controller.
As it is most probably mounted on the motherboard, the simple way to get around the problem would be to use a USB sound card.
Update (04/01/2018)
Hi,
Just covering all bases. ;-)
Cannot find a speaker replacement guide for your laptop but here is a link to the ifixit Asus ROG Strix GL702VM-BHI7N09 硬盘更换 guide, which should get you access to the motherboard. Hopefully it will be easy to see how to replace the speakers once you have got that far.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Faiz Zailani 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 1,077
