跳转到主内容
加入维修社区 - 创建账户
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
DFU mode timeout during software extraction
I'm trying to restore an iPhone 7 that is stuck on the connect to iTunes, but iTunes says there is an error and it can't connect. I tried putting the phone into DFU mode and it connects just fine so I start the restoration process but the iPhone will only stay in DFU mode for about 1 minute before restarting and messing up the restoration. Anyone know how to fix this? Thanks in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
The problem is the iOS file is huge, and it takes too long to download, and DFU mode is impatient.
To fix this issue, first download the iOS IPSW from alink here.
Now, open iTunes and put your phone back into DFU mode.
Instead of straight clicking on the "RESTORE" button,
• on a PC, hold SHIFT, and then click "RESTORE", and select the file you downloaded.
• on a MAC, hold OPTION, and then click "RESTORE", and select the file you downloaded.
This will immediately extract and upload iOS to the phone before it leaves DFU mode.
这个答案有帮助吗?
得分 0
3条评论:
I was able to figure it out. I managed to get the phone in regular recovery mode and restore from there. DFU mode now works normally, so I'm not really sure what the issue was before.
完成的
Nick rose how did you manage to sort it bud,even tho I've downloaded file without itunes,I'm still timing out at the extracting arghhh
完成的
Just had the same issue, Restore only updating OS not erasing settings e.g. lock code, so tried DFU mode, iTunes timing out of DFU mode every time during update. Went back to try simple Restore one last time and it magically worked, settings and lock code are now gone, not sure why but happy!
完成的
添加一条评论
You can just disconnect the phone and iTunes will continue download the OS. When it’s done, re-connect, re-enter DFU, and do the restore.
这个答案有帮助吗?
得分 0
添加一条评论
reinstall iTunes, when prompted if you rather: 1 uninstall and reinstall iTunes or 2 repair itunes. Repair itunes then try dfu reset. worked for me
这个答案有帮助吗?
得分 0
1条评论:
iTunes is part of the OS and has been replaced with the Finder for purposes of restore in newer systems anyway. It can not be uninstalled.
完成的
添加一条评论
添加你的答案
Nick Rose 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 33
总计 9,334
