跳转到主内容
AMD's Eyefinity broke my multi-display configuration
Enabled AMD's Eyefinity and both of my displays can't recognize my computer. If I unplug one of my monitors it works! But I can't disable Eyefinity without 2 or more displays.
Any idea how to fix?
I've tried uninstalling the drivers and re-installing them but it's no use.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
完成的
添加一条评论
1个答案
最有帮助的答案
Radeon software is $@$* for multiple displays.
I suggest uninstalling. Using a registry cleaner and removing ANYTHING related to AMD. Use an driver uninstall utility like DDU.
Then, install everything all over again.
Once you get everything all installed fresh and have all three monitors working (not with Eyefinity) - open up Radeon, go to Eyefinity, Advanced Setup. When that window open up there is a "Presets" section at the top left - create a preset for your current configuration. After you create that preset - create your eyefinity setup. Once Eyefinity is setup correctly go to the same location and create a preset for that.
Once this is done you can go to that same location and choose the preset you desire. That should work. The old versions of Radeon had a way to create a shortcut in the toolbar radeon software so you could easily swap presets. It was still a HUGE pain to get the setups correct. But, once you did it worked pretty well. Now, it is just a huge buggy mess to do this.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Harvey Vance 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 3,820
