跳转到主内容
Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
Error -36 when trying to copy files from SSD
When trying to transfer files from SSD to USB key, i keep getting error -36.
Something with corrupted sectors on the SSD.
1. I tried doing a dot_clean from terminal on the folder i wish to copy and on the USB key.
2. tried booting up with Command-R, OS X recovery, to do a repair of the SSD.
Sill no luck. Still error -36
Anything else i can try, or is the SSD "ruined"?
Best
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I am assuming that
a) you have a non-apple SSD, and you have updated to the latest firmware for the SSD
b) you've run disk utility
c) you have checked the USB key for errors or tried another USB key?
On an SSD, if the file you are trying to copy is corrupted, then it is toast.
However you can try in terminal a 'cp -Rfv <source> <destionation>' so that it forces a copy of the file with errors and all.
这个答案有帮助吗?
得分 2
4条评论:
Likely has a M.2 SSD with an adapter ;-{
完成的
The SSD is the original from the MBA.
I ran disk utility doing a repair, but no luck.
Tested with different USB keys.
I will try the 'cp -Rfv <source> <destionation>', thanks!
完成的
It maybe time for a new SSD drive I would strongly recommend sticking with either another Apple SSD or if you want something larger go with either OWC or Transcend both offer good replacement SSD's for your system.
完成的
添加一条评论
添加你的答案
Anders Laursen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 145
