跳转到主内容
How do I install new bluetooth antenna
I have a new bluetooth board and that is easy to install but they unfortunately did not install the antenna at the factory?? So how do I install a new antenna (which can be purchased easily on e-bay) or more precisely where do I route the antenna and where do I attach the other end?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
The bluetooth antenna is probably hiding in the corner. Here's the installation guide: iMac G5 20" Model A1076 Bluetooth board Replacement
See step 4 and look in the corner to the lower left of the card, it may be tucked under.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Kevin,
Every 20-inch iMac G5 I've been in has already had the cable. Did you pull out the power supply to make sure it wasn't tucked away somewhere it shouldn't be? Do a double take before trying to follow these instructions:
http://www.appleselfrepair.info/imac-g5-...
I didn't see a guide for this on iFixit but found that guide via google.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Kevin 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 1,738
