跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
Voice memo/recorder microphone very quiet upon playback
Hi,
Ive just got my hands on a used iPhone 7 4.7 and have just one issue. The bottom microphone works for voice calls yet when recording using the voice memo app the microphone is very quiet on playback. It does pick up my voice if I shout into it, the scrolling noise bar thing does show its receiving sound. If using normal volume to speak into it the scrolling bar thing stays pretty much horizontal.
Siri is working fine, front upper and rear microphones appear to work normally too.
Its just the microphone for voice memo which seems effected. I was thinking of swopping the dock port over but I believe Siri uses the same mic as voice memo so is this really worthwhile?
The phone is running the latest iOS v11.2.6 has never been opened or water damaged. Ive cleaned the all microphone meshes of dust etc.
Anybody got any ideas? Could this be an audio amplifier IC failure at all?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It is far more likely that the barrier in front of secondary microphone at the top of the phone has filled with dirt and oil. This microphone sits next to the earpiece speaker, so often the two will become muffled at roughly the same time.
Sometimes this issue can be resolved by cleaning the outside speaker grill with a sharp pick and a toothbrush. However, I usually find it must be cleaned from the inside to be effective.
This would involve removing the screen first. Then you will need to unscrew the front camera flex and earpiece speaker. With the aid of heat, the front camera flex can be peeled away without damaging the several components on it. I would then use some heat and fine tweezers to pull the water proofing layers and rubber earpiece guide away from the glass. You can then use a pick and toothbrish to break up and push the debris out out the phone back though the earpiece mesh. I also prefer to put a drop of powerful solvent on the earpiece mesh and blast through oily gunk with compresses air. Care.must be taken not to allow liquid near the LCD.
In reassembly the phone, you should replace the glue seal between the screen assembly and housing with a new one
这个答案有帮助吗?
得分 0
4条评论:
Ive had similar on a 6 where there was no audio using Whatsapp video call. Turns out the front top mic was the cause. I have the 7 seals so might give this a go too. Thanks Adam.
I will post if this is indeed the solution
完成的
Ok, so I fixed this problem just now by installing a new dock port. It turns out that the bottom right hand microphone (next to speaker) had a tear in the flex cable just below the mic itself. All working fine now so am happy it was an easy fix.
完成的
Hi!! How did you install that dock port? Is it hardware or software? Sorry for my ignorance, I'm having a similar issue, not able to record any voice note in any app. Thanks!
完成的
@christianc By the way Siri uses the top microphone
完成的
添加一条评论
添加你的答案
Christian 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 39
总计 12,030
