good battery will not start
motor will turn if jumped, but will not turn with key
A better description of your problem would help a lot. Also are you bypassing the seat safety switch? Have you replaced the blade disengage safety switch lately. Use a multimeter to test continuity of the starter switch.
这个答案有帮助吗?
+ Nice mayer - Also are you pushing in on the clutch/break?
clutch brake does not work.
这个答案有帮助吗?
David Langlois, are you answering the question or are you saying your clutch brake does not work?
New battery, Power getting to Solonoid , engin will not crank period. Like the battery was dead. where is seat safety, how do you get to it and the same question for safety switch for blade disengage swithch??? thanks.
这个答案有帮助吗?
when i jumped the battery the engine started and was running. when i pulled the cables off the battery the engine dies
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,908
