跳转到主内容
Here are the repair guides for Xiaomi Redmi Note 4X
36 个问题 查看全部
Charging the phone after getting wet
My phone got wet a few days ago but it worked fine so I payed no attention and used it normally. But yesterday I plugged it in and it didn't charge. I dissassembled it, I cleaned it, I followed every advice I found in the internet but it still didn't work. But now I tried to plug it using pressure and at some point it started charging. I used a rubber band (:P) and I left it in. I wonder however if I should do it or not. Is there any possibility it breaks down or explodes?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
@lefterios you didn't tell us how you cleaned it. If not properly cleaned it will continue to corrode and continue to fail. After proper cleaning you must replace the battery. After that re-evaluate what damage you really have. Right now you will only find yourself replacing parts based on guesses.
这个答案有帮助吗?
得分 2
4条评论:
Is there a possibility somehing else has damage? Phone works fine
完成的
@lefterios Did you clean it and replaced the battery?
完成的
I have ordered the battery and I'm waiting for it
完成的
The battery wasn't the issue it still doesn't charge. Most probably the charging port is damaged.
完成的
添加一条评论
If inside is clean. I suggest you try replacing your charging port.
这个答案有帮助吗?
得分 1
1条评论:
I'll try that! If you know a trustful site to order it please let me know
完成的
添加一条评论
The first thing I would try is disassemble and soak the main and sub boards in 99.9% alcohol. Leave for an hour or so then look for any corrosion and scrub gently with a soft toothbrush. Allow it to dry thoroughly and reassemble.
I doubt the battery is damaged.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
lefterios 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 16
总计 2,678
