跳转到主内容
Repair guides and support for your Panasonic microwave.
11 个问题 查看全部
Fuse blown on Panasonic Dimension4 Microwave/Convection the Genius
I experienced a power surge in my house causing numerous items to not work. On a few of them, I simply replaced a small cartridge type fuse (3 or 5 amp glass/ceramic type) to get them working. I took apart my microwave oven and sure enough there was a small fuse on the main control panel (front keyboard) that was blown. I replaced that one - BUT upon plugging in the oven, the replacement 5 amp fuse immediately blew. There is no apparent damage to any of the electronics and there is no 'burnt' smell present. There is a small board that appears to be a 'power board' of some sort - identified as B692Y - with black input and output wire connection points and white wire connection points - with a coil in between. This board clearly shows a 125V FUSE 15A - but there is no apparent fuse - or one that I recognize - with no apparent damage. I do not know what to do to proceed and any suggested course of action would be appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi stren7 , sorry to hear about that, normally if fuse flown, means there are more serious fault which need attention. possible to take the picture of the power board you had mentioned for us to look? do you have a multimeter with you?
完成的
stren7 use this guide to add pictures to your question 在已经存在的问题里加入图片
完成的
添加一条评论
1个答案
已选择的解决方案
Hi guys, I am working on getting a pic that I can upload. I do have a multi-meter. I will work some more on getting a pic.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
stren7 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 1,696
