跳转到主内容
The Microsoft Lumia 535 is a Windows Mobile smartphone developed by Microsoft Mobile. It includes a 5-inch display and a 5-megapixel front-facing camera.
27 个问题 查看全部
Accidentally pulled off Coaxial Connector on board
Title says it all. Was wondering if I can solder it back on, or there is a trace I have to glue down. Or if neither will work
Update (03/16/2018)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Jacob, try to post a very sharp and high resolution photo of the board, focusing on the position of the pulled part.
完成的
This is unfortunately the best I can do.
完成的
添加一条评论
2个答案
最有帮助的答案
@snakes202 you need to solder this back on. The pins in the North and South direction on your board (picture one) need that connected to carry the signal
这个答案有帮助吗?
得分 1
3条评论:
Is that all it is? It looked as if I had damaged the board when it ripped off, meaning something other than the data pins and ground were connected.
完成的
@snakes202 hard to see but you may have lost the solder pad on the "north" connector. A clearer /zoomed image might confirm this. Ultimately, yes that is all it is.
完成的
I will attempt a sharper picture later. Thanks
完成的
添加一条评论
If on pcb pads is still in place then flux it and drag solder it or shield the plastic part up and with hot air rework station.
And if you are not that lucky, then you will need microscope and lots of patience. Or send me if you located in uk and ill have a look at it free of charge. Just you funding postages both ways ;)
这个答案有帮助吗?
得分 0
5条评论:
Assuming I can not fix it, what would be that cost for you to fix this? A replacement board only costs $50.
完成的
free of charge, thats easy repair, you will need just to cover postage expenses both ways
完成的
Jacob, have a look how much it would cost you postage to London se14 6qp and if its cheaper then replacement board, let me know... same day as i will receive it ill post it back to you.
完成的
Hi, I am sorry for the late reply. I really just need this fixed, and I am not wanting to purchase and experiment in learning a hot air rework station right now. I would like to send the board to you. I appreciate your generosity, but I would like to pay or go through some medium (Like PayPal) for assurance purposes (this is not my board). Please let me know, thank you.
完成的
Thats fine paypal is good enough. Email me iggy.gedgaudas@gmail.com and we can sort it out
完成的
添加一条评论
添加你的答案
Jacob 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 146
