跳转到主内容
加入维修社区 - 创建账户
联想于 2008 年推出的 ThinkPad。这款机型面向需要低成本笔记本电脑,但又无法在主要功能上妥协的小型企业市场。
Supervisor Password Thinkpad SL500
Hi there,
I have a Thinkpad SL500, with a supervisor Password, which I do not know. Does anyone have a clue how I get rid of it. As far as I have read, theres no eeprom on this motherboard which I could short to get rid of it. There is no power on or Harddisk password inserted. Removing the bios battery does not help either now it just ask every startup to correct time and date.
Greets Simon
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
My SL 500 too is lock and Iam experiencing the same problem
由完成的
添加一条评论
2个答案
最有帮助的答案
You'll find a couple of liks to recovery password generators at the bottom of this page:
https://therestartproject.org/wiki/UEFI_...
But according to the Service Manual there is no procedure for resetting the Supervisor Password. You have to replace the motherboard. If you can find and replace the BIOS chip that might be a last resort solution but you’d almost certainly have to source one from another laptop of the same model, in which case you’d be better off swapping the entire motherboard.
这个答案有帮助吗?
得分 1
2条评论:
Lenovo is not suported, I have an error code, but it is a code you can lookup in the manual of the SL500.
由完成的
Also cmospwd does not work
由完成的
添加一条评论
Probably not the answer your looking for but if you have a heatgun/good soldering skills you could try replacing the bios chip: https://www.ebay.com/itm/BIOS-CHIP-LENOV...
这个答案有帮助吗?
得分 0
1条评论:
I would rather perfer a solution which does not include replacing parts on the mothermoard. Although if there is a solution like with most other ThinkPads where there is to analize a Signal or short some contacts this would be ok.
由完成的
添加一条评论
添加你的答案
Siki 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 25
总计 1,089
