跳转到主内容
加入维修社区 - 创建账户
Xbox One 无线控制器型号 1697 发布于 2015 年,取代了型号 1537 控制器,并修复了 1537 型号中发现的一些问题。1697 型号控制器内置了 3.5 mm 耳机插孔,使其无需适配器即可兼容大多数第三方耳机。此款控制器已停产,并由型号 1708 控制器取代。
How to fix my dpad?
all dpad directions seemed to work fine, until the down button stopped working (left,right and up are fine)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Mathew--There are small tabs on the dpad, it is possible the one on the bottom has broken off causing a miss alignment with the botton on the board. I would suggest using the repair guide to open it up and see if this is the case. If so you can purchase dpads rather cheaply. Hope this helps.
这个答案有帮助吗?
得分 3
添加一条评论
The D-PAD buttons on the Xbox One controller are small metal domes. Sometimes, they worn out and need to be replace. The good news it that they are help in place by a sticker and are pretty cheap and easy to replace.
This video should also help you out to do the repair and to install the new buttons : https://youtu.be/qJf9KZ0H1UQ
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
mathew y 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 50
总计 14,284
