I cant able to on my phone
i cant able to open me phone but when i put it on charging its shows charging on display. i also check switch but switch is OK. i cant understand why my phone cant able to start. please help me as early as possible.
sumit sharma start with the easy stuff. Replace your battery. Just because your phone says it is charging does not mean that your battery actually works. After that check things like this
这个答案有帮助吗?
I already try yr solution but same problm happens
sumit sharma you did not mention that you already did that. What else have you checked? is it a new battery? what is the voltage on the battery?
3.7 battery voltage
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 54
