跳转到主内容
加入维修社区 - 创建账户
Satellite C660 是东芝于 2010 年左右发布的一个笔记本电脑系列。它们配备 15.6 英寸屏幕,并搭载各种不同的英特尔处理器。
keyboard and mouse not working
after a fresh install of windows 7, or 8 , or 10 the keyboard and touch pad stop working. what is the answer!!.......going insane trying to find the fix
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
4条评论
Do you have a USB keyboard and mouse so we can use it to fix it?
完成的
Thank you for replying. Yes, I have USB keyboard & mouse. The laptop keyboard keys e, i, o, u, y, v, and the line of numbers 1 thru 0 do not work. Also, some keys on the USB fail, but between the 2 blimey!
I have installed win7, 8.1, and 10 several times and with different versions. I have uninstalled, re-installed devices and drivers. I have downloaded new drivers from both Toshiba and Driverpack I have done a regedit, a msconfig, and yes I have replaced the laptop keyboard. I have tried installing from USB, and DVD. The hard drive has been formatted and overwritten. RAM has been swapped around and changed. The ribbon cable underneath is clean with no signs of damage, likewise is the corresponding socket on the motherboard. I downloaded the Intel fix, to be told that machine was AMD.
D'oh!
It would appear that others have had similar problems, which have been fixed.This is most vexatious.
help me obi wan Kenobi you're my only hope!
完成的
Mouse not working keypad not working
完成的
sir toshiba c660 main mouse and keybord not working
完成的
添加一条评论
1个答案
最有帮助的答案
Some laptops require model specific drivers that Windows cannot make up for with its basic drivers. If you decide to do a manufacturer recovery, all drivers will be included along with your Windows. However, if it is a fresh installation of a regular copy of Windows (not modified by the manufacturer), you are likely missing drivers that are required for keyboard and mouse to work
Use the following site to download official drivers:
http://www.toshiba.co.uk/support/drivers...
Fill out the form to find the correct drivers and install them on your laptop. This should resolve your issue unless apart from reinstalling windows, you have also taken it apart and forgot to plug in the mouse and keyboard connector on the motherboard.
这个答案有帮助吗?
得分 2
1条评论:
here's the worldwide version of the site: https://support.toshiba.com/drivers
完成的
添加一条评论
添加你的答案
nick smith 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 33
总计 2,725
