跳转到主内容
The Sigma 24-70mm is a standard zoom lens by Sigma with a fixed f/2.8 aperture and close-focus ability.
6 个问题 查看全部
Lens dropped into salt water
Hey community,
I dropped my mirrorless camera and my zoom lens into saltwater earlier today. They were both completely submerged for 15 seconds.
I did not try turning the camera on after getting it out of the water.
I immediately dried it and removed the memory card and battery.
Is there anything I can do to salvage the lens?
Is there anything I can do to salvage the mirrorless camera?
Any insights will help.
With sincere thanks,
G
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
@g12345 it will help if you let us know what make and model your camera and your lens are. Biggest issue you will run into is corrosion. For now you do not want to do anything with your camera. Do not try to run it on, plugging it in etc. This potentially can make a bad situation worse.
Salt Water will get your components to corrode very severely. The very first step I would take is to disassemble your camera/lens. Take a careful and close look at all components and connectors. Truly assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. After that I would suggest that you clean it a couple of times in sterile water, not drinking water (that might have helped right after it got submerged in the salt water). Use a soft brush and clean it very, very thoroughly with the sterile water. You will have to remove all the EMI shields from your boars etc. Once you got the gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for a Apple iPhone 3G but it is still pertinent to your camera as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. Do not use drinking water, if you need to use water, use sterile water. Also, you do not need to leave it to dry for a day. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water. The importance here is the cleaning. Of course,if you can get it professionally cleaned then consider doing it. Ultrasonic cleaning would be the best. Only after you have it completely cleaned can your reassemble and test out what damage it received. the same goes for your lens. At this time it would probably be best to place both, the camera and the lens, inside a paper bag inside your fridge. That will at least slow the corrosion process down
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
G12345 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 11
总计 1,101
