跳转到主内容
型号 A1136 / 30, 60, 或 80 GB 硬盘 / 黑色或白色塑料面板
Why won't my iPod 5th Generation turn on?
My ipod shows signs of life and all of that, and it comes up and says i need to plug it into my itunes to restore it. I did this sevral times and it would not show up in itunes at all. it is making me irritated because i spent alot of money on it and it's a 64 gb......... Please help!
P.S. I even charged it for 24 hrs straight and still did nothing
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
It also has a sad face icon...
完成的
添加一条评论
1个答案
最有帮助的答案
I would first clean the dock connector as well as trying a different cable and a different USB port on the computer. I'd start of there, then go with a new battery after that. You mentioned that you charged it, did it take the charge. You say it's 64GB are you using a CF conversion on your iPod? The only other problem that I can see is that you may need a new HDD. The sad face makes me believe that your hard drive is on its way out. Good Luck
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
dpickle99 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 959
