跳转到主内容
Monochrome laser printer introduced in 2012. The printer is rated for 35 PPM and the first page comes out in 8 seconds. Depending on which model you own (a/n/dw/dn/dne), you will have different options and available features. Uses HP 80A/80X toner cartridges.
What is causing the printer to squeak while printing? *With video*
I have an HP M401n here that I have had for ~3 years or so. As of today the printer began squeaking during a print job. I specifically hear this squeak a little bit while paper is being picked up (Tray 1 and Tray 2). This prominently happens during the fusing stage of the process, but is also present during paper pickup.
I have tried the following things:
  • 7 page test run with the original HP 80A (very low state) with squeaking issues.
  • 7 page test run with the same test document as the original HP 80A using a V4ink 80X toner. This toner also squeaked.
  • Used Tray 1 and Tray 2 for both the original HP 80A toner and the V4Ink 80X. Both trays squeak.
Since this issue is reproduced on both cartridges, it's likely a printer fault. When I got the V4ink toner the 2 pack wasn't much more with a lower cost per toner. Because of that, I ended up getting the 2 pack. I am willing to use the other V4Ink toner in the 2 back I bought for testing, but this isn't ideal since open HP toner is hard to store.
Update
Due to a small intermittent leak (along with the squeak), I changed the toner cartridge with my 2nd unit. The printer still squeaks.
I have now checked the MP tray gears to see if that had any obvious wear - it does not, nor do I see anything serious wrong.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
I'd say try manually turning each part until it squeaks. on the squeaking one add lubricant.
这个答案有帮助吗?
得分 0
4条评论:
The gears don't need to be lubricated. It seems to be caused by a worn out or loose gear. I just need to find it.
完成的
M method appli s. Just replace the gear too
完成的
It turns out the problem is also caused by 2 chewed up gears. The problem is no amount of lubrication can repair that.
It's also in the worst spot possible. In order to replace these gears I need to do a partial teardown.
完成的
I mean, you still need to lubricate the replacements.
完成的
添加一条评论
添加你的答案
Nick 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 19
总计 20,499
