跳转到主内容
加入维修社区 - 创建账户
型号 A1136 / 30, 60, 或 80 GB 硬盘 / 黑色或白色塑料面板
powers on but no sound...
ive got a couple of ipod videos and they appear to be OK, turn on and play music but there is no sound....i tried a new replacement headphone jack but still no joy...could it be logic board??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Do you have an iPod dock? If so, test to see if it plays sound through the dock. There are Bluetooth adapters you can find on Amazon that plug into the dock connector, so if it works, buy one, and a pair of Bluetooth headphones, you will be able to listen to music that way.
Bluetooth adapter: https://www.amazon.com/s/ref=nb_sb_noss?...
完成的
添加一条评论
1个答案
最有帮助的答案
steve Connolly  there are some issues with some of the boards. First you should tell us if it syncs properly and if you can access your files with music while the iPod is in diskmode. After that you want to place your iPod into diagnostic mode and see if you get any errors (you may get a FW error). If none of that shows any issues, you may have problems with the audio IC. In the case of your iPod I am leaning more toward this problem. This particular model has a problem with an IC on the logic board. You can try and see if you get sounds by applying some pressure to the right lower side of the ipod, almost between the click wheel and the bottom corner. If you should get sound by doing so, then you only have very few options. One is a new logic board, the other one is to reflow your old logic board.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
steve Connolly 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 6
总计 173
