跳转到主内容
The third generation of the Toyota Camry in all markets outside Japan. 1991-1996 was also called the XV10 series of Camry vehicles.
79 个问题 查看全部
Pull the engine to replace a timing belt on a 1991 Camry?
Do I have to go as far as removing the motor to replace a timing belt on a 1991 Camry? Anyone know of a good website I can download a repair manual for my car, for free?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Does not read like you have to remove the engine, but definitely the engine mount on the right. Not a fun job but doable...besides the advise that ABCellars gave you here is another website that has some info
这个答案有帮助吗?
得分 2
添加一条评论
No, you don't have to remove engine. It's sufficient to hold engine with jack and block of wood underneath oil pan. Shouldn't be too much of a hassle...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jesse 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 2,064
