Why does the turntable not rotate?
Unable to open case because screws are hex with a pin in the center that keeps a tors bit from unscrewing the screw. I would like to replace the motor for the turntable.
Here is a [关联产品丢失或禁用: IF145-044] that will help you crack the case on that sucker. Once inside, most microwave turntable motors are fairly simple to remove. I've heard that people go around scrounging them out of the trash because they're slow RPM motors that take 120v. Perfect for your disco ball or other slow rotating needs.
这个答案有帮助吗?
+ good answer. Disco Ball? ;-)
Every home should have one ;-)
I have a lava lamp, does that count? ;-)
dunno...do you dance round it?
only after listening to ABBA and to much Alvin Stardust ;-)
There are some security screws that protect the microwave from opening by everyone. The screwdrivers that open this class of screws are sold on any tool store like harborfreight.com or Enco. They are not difficult to find, but cannot be find everywhere as other screwdrivers can be found.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 4,592
1条评论
What is the brand and model number of your microwave please?
由 ABCellars 完成的
