跳转到主内容
加入维修社区 - 创建账户
由 Apple Computer 于 1989 年发布,1991 年停产。
Loud Humming Coming From (Presumably) Floppy Drive
It might be also important to note, that to get it to boot, I have to hold down click on start up
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Floppy drive works? Eject works?
Usually the eject mechanism in the floppy drive gets stuck by the age and hardened grease and chews one plastic gear which would result in non-stop operation of the eject motor.
Click on startup would trigger floppy an eject before boot attempt.
这个答案有帮助吗?
得分 0
1条评论:
I am aware, my problem is after this it still makes the grinding noise
完成的
添加一条评论
So, did you replace the eject mechanism gear? You must also thoroughly lubricate the other gears and check that everything moves freely.
As the machine is almost 30 years old now, the floppy drive must usually be cleaned and relubricated to restore its proper function. All the rails and other moving stuff should be relubed..
Did you check that the head assembly can move freely on its rails? If not, you would need to put some lithium grease on it. This can also cause the grinding noise when the head is stuck and the actuator would try to move it.
Also the main motor can rub onto something underneath, which would cause grinding noises...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Izzy Harding 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 717
