跳转到主内容
PlayStation Vita(PSV)是PSP的后续机型。PSV具有更加强大的处理器与画面,添加了第二个类比摇杆。PSV发售于2012年2月15日。
169 个问题 查看全部
not taking a charge or powering on.
My PSVita will not take a charge or power on I bought it from a pawn shop a while back and it would not do anything and they would not take it back what might be the problem and how would I fix it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
So I will get a new battery as soon as I get the money what is it like $15
完成的
添加一条评论
2个答案
@fatedengram this can be an issue with the charger, the charging port and/or the battery. Use a multimeter and check your charger to make sure that it has the proper voltage output (5V). If that is okay check the power port and change the battery while you are at it. Use these guides PlayStation Vita to work on it.
这个答案有帮助吗?
得分 0
4条评论:
I will need to buy a multimeter then to test them.
完成的
i tested the battery and the charger the battery im getting 2.82 and i tested the charger connected to the motherboard and im getting.14 with the wall outet .02 with the usb plugged itno my laptop if i tested correcctly.
完成的
@fatedengram "the battery im getting 2.82" start with a new battery. Not sure where you tested for the voltage on your port but either one is to low.
完成的
I disconnected the battery from the motherboard and tested the connector
完成的
添加一条评论
Try opening it and unplug battery and plug back in then charge it. Sometimes that can fix. If slim model the android style charging cables are junk and often go bad. So it maybe your charger.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jake Romine 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 23
总计 1,633
